exhaust install
[QUOTE]Originally posted by turbo_pwr
[B]I should add that some people have had problems stripping the bolt so it might be better to go to Honda and buy a spare (can't be that much) before you start.
Originally posted by BigWave10
Over the years I've found by spraying a product called "Screw-Loose" on the bolts one day prior (just lay on the ground and shoot 'em from a distance) then once a few hours prior to install, even the oldest, toughest exhaust bolts are ready to come off-- almost without a wrench.
Try it!
Dave
Try it!
Dave
Does anyone know where I can get that stuff?
Just installed my comptech exhaust tonight. Leave yourself a couple hours. I no master mechanic, but it isn't that hard. It is a 2 man job getting the stock exhaust out. Be careful with those bolts. I cranked on them pretty hard when I put the new one on. I felt a slight slip (very slight, but a slip nonetheless) on one of the bolts. Ill go back tomorrow and tighten all the bolts, as per the instructions, to see if it is stripped.
The hardest part of the job is getting the rubber hangers off when removing the stock exhaust. I used a long heavy screwdriver and pryed it against a frame member for leverage. Works well.
bill
bill
Spray WD-40 or silicon spray on the hangers. They'll be easier to take the mufflers off and put the new ones on. Yes. Nearly all parts stores like Pep Boys have jack stands (pretty cheap).
Originally posted by Eze8199
anyone know how much the neuspeed exhaust weighs?
ElNico
Aug 26, 2012 02:23 PM
