Exhaust Install
Old Dec 1, 2005 | 06:13 PM
Spec_Ops2087's Avatar
Default Exhaust Install
Search is down atm, but I've done a little research before and it seems the exhaust install is not overly difficult. I do have some questions on the install though:
(I will be installing an Invidia)
1. How safe is the car on 2 jack stands holding up the rear. Do I have to worry about it falling?
2. After looking at the "how to install an exhaust" FAQ, it seems I do not have all the large torque wrench the guys had in the 2 threads. Is it nessary to have a torque wrench or can I use a regular ratchet wrench and just estimate the tightness?
3. Neither my dad nor I have ever installed anything remotely close to this, people say about 1-1.5 hours for a complete beginner. Can anyone vouge for this?
I have the choice to have the local midas install it for probably 100 or so but I rather save that money and spend it on something else.
I'm basically looking for some encouraging words
Thanks
Old Dec 1, 2005 | 06:18 PM
Mikes256's Avatar
Use two jack stands with the jack underneath also. Can never have too many precautions.
edit: Can you post pics as you do it. I wanted to do my own exhaust next summer, and i'm a beginner also. I hope it works out for you, good luck
Old Dec 1, 2005 | 06:19 PM
whiteAP1at9k's Avatar
hey i just got my fuji exhaust installed yesterday and it cost me 35 bucks... and only about 30 mins. i was quoted 35-65 dollars maybe you should find a better shop with a better price?
Old Dec 1, 2005 | 06:36 PM
littlerocket777's Avatar
Put 2 jackstands in the back jack points. Put wooden blocks in front of the front wheels. Put the jack under the differential (you jack it by the diff anyways). If you have them ramps you drive up on, it's even better cuz you get more clearance to work with.
I've never used a torque wrench and that's mainly cuz I don't have one and I'm too cheap to get one. I've gotten along just fine.
When you're under the car, use a breaker bar to loosen bolts, try not to jerk around the bolt too much, it'll make the car start to sway. Kinda scarry in my opinion.
Old Dec 1, 2005 | 06:45 PM
XclusiveAutosports's Avatar
This is something that you can definitely do yourself. I installed mine by myself so if you have your dad help you out you will be just fine. I have ramps that I backed my car up onto at the time, before I had my car lowered, but they helped out a lot instead of having to jack up the car and use jack stands. If you are going to use jackstands though, you can jack up the car in the back at the diff and put your car on jack stands. Then get yourself some wd40 or liquid wrench and spray the bolts before trying to crack them loose. You can also spray the rubber grommets that hold the exhaust hangers. Its pretty straight forward, you only need one socket size for the three bolts on the cat, remove the stock exhaust and bolt up the new one. Good luck
Old Dec 1, 2005 | 06:49 PM
Thanks for the encourging words guys!
Another question -- which size socket do I need for the bolts?
Thanks
Old Dec 1, 2005 | 06:57 PM
321contact's Avatar
Make sure that the weight of the car is mostly on the jackstands if you are going to use a another hydraulic jack for additional support. Honestly, though chocking the wheels and using good quality jackstands will be sufficient and safe.
Make sure the car is on level ground as well.
Old Dec 1, 2005 | 07:31 PM
Hey, you may want to check out these two threads:
Removing Stock Exhaust
Installing a Catback Exhaust
Have fun
Simplegreenvr6
May 19, 2013 11:22 AM
ar10
15
May 23, 2010 08:34 AM
chrisgood1
Mar 12, 2010 03:55 AM
s.hasan546
39
Sep 21, 2007 04:05 PM
s.hasan546
Sep 19, 2007 09:19 PM
