Expensive Gas - Does the s2000 HAVE to have it?
Originally Posted by CrazyPhuD,Nov 7 2005, 06:46 PM
Let's put it this way....if you can't afford the gas you can't afford the car(i.e. tires insurance, etc....)
Feed it 91 octane or better, or sell the car. Period. If you want to have a sports car, a real sports car......give it what it needs or don't own one.
I know for a fact that there a members of these forums that have a lengthy commute, and are not complaining about putting expensive gas in their S2000
I for one and am not rich. But the S2000 is a very affordable sports car. I am just will to spend a bit more at the pump for some good ole fashion fun driving. If you are such a tight ass you can't do that, buy a Civic. Fast/fun and cheap in most situations don't belong in the same sentence, but in the case of the S2000 I feel like I am ripping someone off.
LOL you guys are funny, most of you are ignoring his question, and turning it into a value judgement of whether the car deserves hi-test...
The question was, is it detrimental. And the scientific answer for Variable valve timed engines is a resounding NO, it won't hurt his engine, and it the engine won't "miss" or anything wierd.
And actually, the car runs dang good on 87....
No, you should not run a lower octane than Honda says. All higher octane does is resist detonation. In a high conpression engine such as the F20 this matters. Just because a Civic can VTEC on 87 does not mean that is OK to do so in an S2000. The ECU in the S2000 can detect knock from the engine and pull timing to some degree. It is my understanding that the ECU is constantly monitoring the knock sensor in order to determine how much timing to pull. If you run a higher octane the ECU will let the timing advance slightly. So in my opinion it would not be wise to run lower than 91 octane in an S2000. I believe there is only so much the ECU can do to protect against detontaion and poor judgement.
To detect knock, the ECU must see that there is knock first. If you run with 87, the car will knock, and it will run really bad. The guy I bought my car from started filling with 87 (told me as I took the keys and was about to drive off) when the gas prices started getting bad this year. I immediately finished the tank and refilled with 93 octane. I saw in immediate performance increase. The car was actually ABLE to idle well and accellerate smoothly.
If you cannot afford the extra 2.00 per fillup for premium, than this car is probably out of your price range.
To the guy with the excessive "
" : grow up. We're not putting this guy down, we're just telling it how it is. Everyone wants to save money, but if you're trying to save 2.00 every week or so because you can't afford to buy premium, than you should be buying a much more affordable car than an S2000.
Originally Posted by beofotch,Nov 7 2005, 08:39 PM
Can I put in the biodiesel I have been developing in my lab for the last 3 months? I get grease from the local mexican restaurant, and it only takes 16 days to refine. Any luck with that?
You can afford an S2000 and you are complaining about spending 20 cents more per gallon of gas?? thats only like $5 more than the 87 for nearly a full tank of gas??? what else can you get for $5 these days?? If you are saying you cant spend the extra $5 on gas then get another job.
