F20C Engine Study
Old May 30, 2007 | 07:16 PM
RED MX5's Avatar
Originally Posted by tof,May 30 2007, 09:24 PM
I'll take this one since it gives me a chance to talk yet again about my Galant VR4. There are a lot of flavors of this awd turbo in Japan, including some with a "cyclone" intake, a perfect example of variable intake volume. A lot of JDM 4G63T engines come into the US with these intakes. Some Galant VR4 owners install them as an upgrade.
The Goal:
Long intake runners provide better low end torque by producing higher flow velocity at low RPMs. Short runners provide more high end power because they allow better less restrictive breathing at high rpm where flow volume is more of an issue than flow velocity. (Any wonder the S2000 uses low volume short direct runners?)
How they work:
On a variable volume intake there are two sets of runners built into the intake, one longer and one shorter. Air is directed through one or the other set by valves that transfer the intake flow from the longer runners to the shorter ones as RPMs rise. The idea is to give you the best of both worlds, kind of like if you took mild cams for lower rpm grunt and combined them with more radical cams for better....oh, yeah, we have that already.
Our RX-300 has a similar setup. A "flapper valve" in the intake is actuated using vacuum that is controlled by the ECU. I think the engine is the same in the Camry and other 3.0l V-6 Toyota/Lexus engines.
Old May 30, 2007 | 08:36 PM
TheDonEffect's Avatar
Great read, kinda late in teh day and the ADD kicked in, will finish later. Great read thus far though.
Old May 30, 2007 | 09:41 PM
s2k dre's Avatar
the jdm f20c is 11.7 comp?
Old May 30, 2007 | 09:56 PM
iKMTi's Avatar
Banned
awesome. now where the F22C? hahaa
Old May 30, 2007 | 11:09 PM
Eluded's Avatar
hmmmm, it doesn't mention the durability of the mighty f20c
Old May 30, 2007 | 11:23 PM
Lionheart's Avatar
Very old find but indeed very good read for all S2000'ers
Durability of the F20 & F22? Like any other Honda engine
Old May 31, 2007 | 10:31 AM
tof's Avatar
tof
I suspect no one found the F22C a worthy subject for publication of such a white paper.
9 > 8
(36 days and I'm already starting to feel right at home here.
Old May 31, 2007 | 11:00 PM
iKMTi's Avatar
Banned
9 > 8
Hahhaha. That because F22C is the better that why is even krazier that it kept in secret that ya'll cant find it. hahaha
F22C FTW!!!!
Old May 31, 2007 | 11:41 PM
Lionheart's Avatar
9 > 8
Doing great, tof
wantone
Aug 5, 2007 01:27 AM
Psychichi
May 11, 2007 12:16 PM
The Raptor
Jun 8, 2006 02:10 PM
Marco
Dec 13, 2005 04:50 AM
MULDER
Oct 8, 2005 02:19 PM
