Factory cat bolts
Old Aug 25, 2006 | 05:55 PM
frofro24's Avatar
Default Factory cat bolts
I am finally putting my test pipe in. Wondering if the aft most bolts are pressed and can be pressed out easly? Thanks
Old Aug 25, 2006 | 06:16 PM
xviper's Avatar
They are pressed in and no, they aren't easy to press out. Get a new set of regular nuts, bolts, lock washers. Use some anti-sieze on them so you can get them off later.
Old Aug 26, 2006 | 12:49 AM
Rusted_nailz's Avatar
If you talking about the three studs on the end of the cat, yes they are pressed in. But they were not hard to take out. I had one of the studs snap on me when I was installing a new exhaust and what I did was soaked the stud for a min or two with wd10 and smacked it with a hammer and it came out. Then after I switched it with a stud off my integra cat that I had laying around.
Old Aug 26, 2006 | 11:04 PM
frofro24's Avatar
That is what I thought. I was thinking about going to napa and buying wheel studs that are the same size. Do you think they will work? I called honda and they wanted 14 bucks a bolt. If I remember I can get wheel stem bolts for a few bucks each. Oh, and thanks for the advice on the anti-sieze, that stuff is magical. Thanks for the help fellas.
Old Aug 27, 2006 | 05:51 AM
xviper's Avatar
Get the nuts, bolts and lock washers from Home Depot. They don't have to be of automotive origin. There's no pixie dust on 'em.
Old Aug 27, 2006 | 01:29 PM
frofro24's Avatar
Sounds good. Thanks again.
InVTEC
Jan 8, 2013 07:44 PM
JspecVtec
Nov 6, 2008 09:46 AM
Si2k
May 6, 2007 04:10 AM
MuGeN_S2k
Apr 27, 2006 02:27 PM
pjkwong
Jan 24, 2006 03:57 PM
