BRAKE QUESTION
Old Aug 27, 2006 | 10:40 AM
radtech's Avatar
Default BRAKE QUESTION
Whats the best whay to depress the cylinder on the rear brakes. I took a c-clamp to the front ones it it was easy. The rear calipers have no meat on them to clamp to. Any suggestions. Thanks
Old Aug 27, 2006 | 10:42 AM
ReedZ's Avatar
Former Sponsor
Do NOT clamp!! The rear pistons must be screwed in.
Old Aug 27, 2006 | 11:02 AM
radtech's Avatar
Thanks, is it hard to screw them in.
Old Aug 27, 2006 | 11:16 AM
xviper's Avatar
Title:
I need help
A little bit more descriptive title will go a long way.
https://www.s2ki.com/forums/index.php?showtopic=352908
Old Aug 27, 2006 | 11:17 AM
radtech's Avatar
I've tried screwing them, they turn no problem but they don't seem to be moving in at all. Am I missing something. Does it matter which way you turn them, do you have to put pressure on them at the same time as turning.
Old Aug 27, 2006 | 11:21 AM
ReedZ's Avatar
Former Sponsor
Turn them clockwise, they will go in.
Old Aug 27, 2006 | 11:23 AM
radtech's Avatar
Do you just turn it or do you have to apply pressure also. You must have to turn it a lot then, because I turned them quite a bit and it didn't seem like they moved.
Old Aug 27, 2006 | 01:45 PM
ruexp67's Avatar
You may need to turn them a lot in order for them to retract noticably. However, if you have "unscrewed" the piston too far, it will come apart.
WRCGooseS2K
Apr 28, 2013 10:04 AM
jbotstein1
Jan 8, 2006 07:18 AM
freq
Aug 31, 2005 05:03 PM
Pinky
Dec 21, 2001 06:22 AM
cthree
Aug 3, 2001 08:00 AM
