Is fast cornering bad?
Old Jun 11, 2001 | 12:07 PM
WhiteS2k's Avatar
Default Is fast cornering bad?
I can't help thinking that taking sharp corners at a high speed is bad for the tires, but because we CAN do it with the S2000, I tend to do it quite often -- with the squealing tires and all. So is it bad to take a 90-degree turn at 40MPH or faster (on a flat road)? Other than burning out the outside edge of the tires, what else is bad about making fast turns?
Old Jun 11, 2001 | 12:10 PM
SiK182's Avatar
It is bad to have too much fun
Old Jun 11, 2001 | 12:12 PM
Phantom's Avatar
WhiteS2k,
Technically you are putting more stress on the car's suspension components at the least...but that is what the car is for bud...
Old Jun 11, 2001 | 12:40 PM
Eze8199's Avatar
I think it is fine to corner fast, its what the car was intended to do
Old Jun 11, 2001 | 12:54 PM
krhorrocks's Avatar
Just start saving for new tires now and if you hit any pot holes while under that kind of stress watch for signs of being knocked out of align.
Old Jun 11, 2001 | 01:39 PM
WestSideBilly's Avatar
If you don't plan on whipping your car around corners, why did you get an S2000? That's half the fun!
My goal every commute to work: use the brakes as little as possible
Old Jun 11, 2001 | 01:47 PM
jschmidt's Avatar
No, it's good! Verrrry Good!
Old Jun 11, 2001 | 01:49 PM
wanabe's Avatar
from personal experience, my only comment is to be careful in 90 degree corners while accelerating.
i took one wide, hit the gas and lost the rear!
no problem as long as it is not full throttle... (VTECing in turns can lead to unwanted conditions!)
Old Jun 11, 2001 | 02:00 PM
Lips2000's Avatar
It's only bad if you are in the insert car name here behind you trying to keep up with you ass!!
Mark
Old Jun 11, 2001 | 02:04 PM
ReedZ's Avatar
Former Sponsor
Your tires squeal?
