First stick shift pain?
Old Apr 9, 2015 | 07:14 AM
gerry100's Avatar
Originally Posted by zdave87
Take your wallet out of your rear pocket.
+1
I used to drive a car 45k miles a year and learned to remove my wallet before going any distance. It help prevent my back form flaring up.
Old Apr 9, 2015 | 07:30 AM
Conedodger's Avatar
Originally Posted by gerry100
+1
+2 I've gone to a much thinner wallet and carry it in my front pocket.
Old Apr 9, 2015 | 08:48 AM
NNY S2k's Avatar
Levi
Old Apr 9, 2015 | 08:49 AM
Saki GT's Avatar
You should also move the seat back a bit so your thighs have more support.
Old Apr 9, 2015 | 10:39 AM
Short's Avatar
Originally Posted by Conedodger
Originally Posted by gerry100' timestamp='1428592441' post='23572170
[quote name='zdave87' timestamp='1428528986' post='23571432']
+1
[/quote]
I don't keep my wallet in my rear pocket so that is not an issue. Thanks for the idea though.
Old Apr 9, 2015 | 01:58 PM
captainmel's Avatar
You need to strengthen your leg but you also need to make sure you're stretching it too. Massage and physical therapy can help tons with things like this. If I'm in my s in heavy traffic I try to stretch my legs and hips as soon as I'm out of the car.
Try standing on a stair with the balls of your feet on the stair and your heels extending off the back of the stair. Drop them down as low as you can and then use the strength from the balls of your feet to stand on your toes. Hold as high as you can for 20 seconds (use a timer) and then hold as low as you can for 20 seconds. Do this for 5 minutes twice a day. It will stretch your hamstrings really well.
Old Apr 9, 2015 | 03:18 PM
Mr.60trim's Avatar
Originally Posted by dwb993
I had an L4 lumbarectomy a couple years ago to treat pain running all the way down my leg (outboard side) to my little toe. Surgery went a long way to help my pain as it no longer goes down to my toe.
Lumbar Laminectomy*
Old Apr 9, 2015 | 04:53 PM
zdave87's Avatar
Member
Originally Posted by Short
Originally Posted by Conedodger' timestamp='1428593413' post='23572183
[quote name='gerry100' timestamp='1428592441' post='23572170']
+1
[/quote]
[/quote]
No problem. I guessed that you had a wallet in your rear pocket. My other suggestion is sit straight and not do the lean to the right side that most drivers do.
Old Apr 9, 2015 | 10:35 PM
HarryD's Avatar
When I first got my car [used], the clutch required a lot of force to push in.
I recall doing the clutch regrease (and grinding down the nipple) and a fluid change made my clutch feather-light.
See also: https://www.s2ki.com/s2000/topic/370...-clutch-pedal/
Old Apr 9, 2015 | 11:06 PM
EF9 Sedan's Avatar
The S2000 was my first stick shift car. Embarrassingly I had pretty weak legs at the time... I remember that I got a calf cramp while waiting for a light and stalled. I no longer get calf cramps while driving, but I'm hesitant on doing heavy calve workouts if I plan on driving the S in heavy traffic.
