Flat Tire
Old Nov 6, 2001 | 10:31 AM
av8tor2's Avatar
Default Flat Tire
Wow, all I can say is the S02's have a stiff sidewall!
Only knew the tire was flat from the slight pulling of the car to the left.
My question is...now that I have had the tire fixed, there is playing the steering. Will the EPS need to be adjusted? I drove for about 3 - 5 miles with very low tire pressure. Or is the car out of alignment now?
thanks in advance for any advice...
Old Nov 6, 2001 | 11:41 AM
lvs2k's Avatar
I've had a flat on the rear, but didn't suffer the problem you describe after the repair.
Old Nov 6, 2001 | 12:32 PM
txst's Avatar
I also had a flat and don't have any issues with the steering now.
Old Nov 8, 2001 | 04:44 PM
carfanatic's Avatar
Stupid question but here is goes: since you had the tire fixed, have you checked to make sure your other tires aren't low as well?
Old Nov 8, 2001 | 05:25 PM
av8tor2's Avatar
Yep, I have been hyper-sensitive about the tire pressure, 32 psi all around now...
lordepic1
Dec 11, 2006 12:26 PM
Russian
Jun 23, 2004 01:57 AM
cyber_x
Nov 13, 2003 03:22 PM
blue2k2s2k
Dec 17, 2002 02:04 PM
gbaker
Jan 22, 2002 01:51 PM
