Friendly Reminder: Check your oil level!!!
Old Jan 7, 2004 | 02:25 PM
sickestS2k00's Avatar
oops, reminds me i should really check mine right now.
Old Jan 7, 2004 | 03:24 PM
Quik S2K's Avatar
This is a great reminder. I do oil changes so frequently and have never burned enough oil to really worry about it but I will check more often. Thanks for the reminder
Old Jan 7, 2004 | 10:55 PM
chicopaparazzi's Avatar
i have a habit of reseting my odometer every day... i guess i keep track of how many miles i drive in a day... no reason, just some dumb habit... i pretty much check it after every other fillup though
Old Jan 7, 2004 | 11:50 PM
simons2k's Avatar
thanks for the reminder
Old Jan 8, 2004 | 12:14 AM
PortugueseS2K's Avatar
good reminder phase
as a new owner ( bought mine 4 months ago ) I didnt realize the car was known for burning so much oil. Now that i know this, i will also keep a close eye on the oil level. I just changed my oil a month ago and the car hasnt moved since. However, i will go check it tommorrow now that i know this. Thanks again !
Old Jan 8, 2004 | 03:17 AM
aran's Avatar
Read the owner's manual - it tells you to check the oil EVERY time that you fill the car up with fuel, also tells you to check the coolant overflow.
I NEVER fill up without checking the oil - only takes a minutes to pull out the dip stick, wipe it off, and then re-insert - wait a few seconds, pull out and take a reading.
aran
Old Jan 8, 2004 | 03:24 AM
Z06-KILLR's Avatar
thanks for the reminder...I have never had any issues, even while tracking/autoxn' the car....
Old Jan 8, 2004 | 07:03 AM
Phase II's Avatar
No problem. I just thank god my motor still moves, just wanted to pass that on in case anyone else hadin't checked in awhile.
I now reset my trip and check every 100 miles, thanks for the tip Cape Cod.
Old Jan 8, 2004 | 07:13 AM
RazorV3's Avatar
i dont like checking the oil at the gas station because the engine is still warm and can give deceptive readings. i usually let the car sit overnight and check it first thing in the morning(lets all the oil drain to the bottom of the oil pan).
Old Jan 8, 2004 | 07:42 AM
S2K_Stylist's Avatar
yes, you guys should listen to his advice, mine ran out of motor oil... and I had an engine failure.. =*(
