Front brakes
Old Nov 17, 2006 | 07:28 PM
tim62's Avatar
Default Front brakes
Mine is less than 3 Yrs and about 32K miles and I have my front break squeaking. It sounds like a low pad indicator. I dont drive and break hard, in fact, I still have the original front tires (about 40%). Would the front pads wear that fast to yours too?
Tim
Old Nov 17, 2006 | 07:31 PM
spa01s2k's Avatar
I have 42000 miles on the original front and rear pads. No track days and a few spirited drives in the hills.
Old Nov 18, 2006 | 02:15 AM
SpitfireS's Avatar
You can see the outside pad through the wheel.. easy to inspect.
To make sure, remove the wheel and look at the inside pad too.
Old Nov 18, 2006 | 05:00 AM
SIIK2NR's Avatar
Definately check the pads and look at the indicator if it's touching. If not, try using some good brake dust cleaner.
Tim
Old Nov 18, 2006 | 07:53 AM
Sfkn2's Avatar
or you can just swap out the front brake pads/resurface rotors. It's not expensive and you won't have to worry about it again for a bit.
Old Nov 18, 2006 | 01:59 PM
Ks320's Avatar
You may need to remove your wheels to check since you have an AP2 ...
Old Nov 19, 2006 | 03:20 PM
gomarlins3's Avatar
Original front tires at 32,000 miles?!?!?! WOW!! That is amazing!!! I have 24,000 miles and I am on my 2nd set already, looking for my third.
Old Nov 19, 2006 | 07:26 PM
Cycloneranga's Avatar
I just changed my front pads at 48K. They were squealing, but when I got the old pads out they were still at about 25%. Oh well, no more squealing and much firmer feel for $66. I'm happy.
Legal Bill
Jun 2, 2015 07:53 PM
Matt_in_VA
Aug 27, 2009 06:32 PM
JspecVtec
Inland Empire S2000 Owners
Jun 5, 2006 10:59 PM
aggie
Apr 26, 2006 07:12 AM
Relson
Aug 9, 2002 01:43 PM
