G-Tech'd my S2000
Borrowed my friend's G-Tech and did a few launches to see what 0-60's I can get... third try was the best and then I decide to stop and give the car a break.
Dropping the clutch at 7k (ouch!) I managed a 0-60 of 5.4secs...
I'm actually quite happy with that and I'm sure it can dip into the lower 5's as some on the board have accomplished but I wouldn't want to abuse the clutch anymore than I did.
Cheers
Cheers
Damn it loki that's a great picture
5.4 is on par w/my G-Tech times for a 7K launch also. I'd like to know if you did any off idle launches? I usually get a 6.1x off idle. The slightly tweaked 10AE Miata gets 7.79 off idle and the M5 burns it up at 4.85 on good launch.
Originally posted by Typer_00
any sc that have done their gtech runs?
Was only able to do two runs, first was a 5K dump which bogged down a good deal and resulted in a 5.09s. The second run was a 6.5K dump which resulted in such a huge tire smoke show that the rear end kicked out all the way through 1st gear and only snapped back because of the shift to second which resulted in a dismal 5.79 s.
After all the noise and smoke I decided I'd better get the hell out of the area before somebody called Johnny L
.I'm sure if I could drive like a white man, sub 5's are possible.
Maybe I need to hire Sev to drive for me
Hmmmm, interesting loki. I borrowed my cousin's G-Tech last w/e. In about 35degree weather i did my first launch at 6k got a 5.94 (some side way spin which stopped right before i had to shift into second). Tried another at 5-5500......got a 6.2 or 6.4.... Tried another at 4-5 (car bogged down....smelled clutch...) I decided to stop there. I'll try some more when i get more miles on the stook.....(got 1100mi on her now)
Originally posted by Jay Li
RT, are you sure you bogged and got 5.09 or was that a typo?
Are we having a miscommunication of sorts?
That's in response to Typer_00's Supercharger inquiry.
