garage floor covering
I painted my garage with the rust-o-leum epoxy paint last fall. You can buy the "sand" to add to it for traction. The floor came out good, except I would recommend not using the whole container of the sand, even though the directions say to. My floor is a little too rough. It definitely isn't slippery, but it's a little hard to clean up with so much grit.
Rust-o-leum also includes colored flakes that you throw on when the paint is wet to give it textured look.
Originally posted by gdonahue
Can you still use a creeper and did it fill the construction joints in your floor?
Yes I can still use a creeper. I really don't have construction joints on the floor. It isn't a filler, though and if you need to fill, you should do that first. The key to using this or just about any other concrete covering product is preparation. Rustoleum includes a clean product and the process takes a few days to do with drying time, before you start painting. You want to be sure and remove any oil or grease areas. There's nothing worse than having portions of your new painted floor, peel off.
I always thought the joints in concrete floors were expansion joints to help concrete from cracking during temp. changes in the weather.Am I wrong?...if not I'm not sure I'd want to fill in the joints.
SakeBomb
24
Feb 21, 2011 03:55 PM
TFota
Jan 3, 2001 06:38 PM
