Glass or Plastic?
Old Mar 30, 2004 | 01:02 PM
mbilderback's Avatar
Default Glass or Plastic?
I drive an 01, and the only major issue I have is the plastic rear window, I'm looking at a second replacement already....Note that it's always been a shop's fault. I was wondering if anyone has ever actually replaced the plastic job with a glass top? I know you have to remove the top and replace it with the glass top, not just the window insert. Anyone done this?
I talked to the local auto upholstery shop and he said he did it to an older Miata and had massive troubles with the spring loaded rear brace.
Old Mar 30, 2004 | 01:16 PM
folex187's Avatar
There's a PDF on here somewhere that describes the conversion. I believe you have to make a couple elastic straps but you do have to replace the entire top and I think that is a 10+ hour job.
-Alex
Old Mar 30, 2004 | 08:49 PM
allkingz's Avatar
No offense, but why are you on your second replacement?
Old Mar 30, 2004 | 09:09 PM
subdriver's Avatar
I haven't replaced a S2000 top (since I don't own a S2000, yet). But I've replaced the top on a miata. Top replacement should be a relatively routine job for an upholstery shop. It sounds like the one you went to doesn't have too much experience with them, you want to go to a shop that does top replacements on a somewhat routine basis. Also, I don't know if this is how it works on the S2000, but on the miata you can either buy a new top and the shop has to actually take your old top off the frame or you can buy a whole new top and frame and all you have to do is swap out the two.
Old Mar 31, 2004 | 12:16 AM
nigashorty's Avatar
do a few search...i have an 01' also and it bugs me ...it gets stratches, bent, etc... hardtopguy sell them for $800 and instructions on how to install it yourself is in this forum..just search it...
Old Mar 31, 2004 | 01:23 AM
VTEC_Junkie's Avatar
Old Mar 31, 2004 | 01:45 AM
1a-race's Avatar
Banned
Old Mar 31, 2004 | 06:36 AM
wannabuy's Avatar
Get Glass. That is all I would say.
Old Mar 31, 2004 | 07:51 AM
afetsman's Avatar
Here's a thread on it...
http://forums.s2ki.com/forums/showthread.p...&postid=1120489
Old Mar 31, 2004 | 05:07 PM
Well, 1: Honda scratched the plastic when they replaced the top latches with the hard top latches.
2: Now I've got to get a quote to see if they can buff out these wierd spots that got put on there by another shop fixing a small ding. It's getting old.
