Going to the Drag Strip Today
Old May 19, 2006 | 07:26 AM
rikhemi's Avatar
Default Going to the Drag Strip Today
I currently have an intake wiht 4.77 gears on the car. Im hoping to achieve a 13.5 in the qurater mile. When I was stock, I was able to get a 14.2. Im probably going to have a couple runs and was wondering is one of the most important things the 0-60 time. I heard many talk about getting that under 2 sec to achieve a time under 13.9. What is the ideal time slip usually for an s2k which runs 13.5 so I could know what I need to work on when Im out there. I want to be able to tell after the first run if my start is the problem or my shifting
Any inputs would be appreciated.
Thanks
Old May 19, 2006 | 08:29 AM
soozookabluS2k's Avatar
i think u mean the most important is the 60 ft time. Just get a good launch nail your shifts and i think you could be close to that time. What was your 60 ft time on your 14.2 run?
Old May 19, 2006 | 08:34 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Good reactions will yield sub 2 sec 60 feet time (1,8--1.9)and you should get around 13.2's quarter time.
My stock "S" used to get consistent 13.7's.!!!
Old May 19, 2006 | 08:46 AM
i see ur from SF too. U goin to moroso?
Old May 19, 2006 | 08:51 AM
clawhammer's Avatar
I'm sorry, but reaction doesn't have anything to do with the 60' times.
Keep this in mind: .1 sec at the 60' = .2 of your 1/4 time. That means if you can improve your 60' by .1 sec, then your 1/4 time will drop by .2 seconds.
Old May 19, 2006 | 09:10 AM
rikhemi's Avatar
When I got a 14.2, I had a 2.3 reaction time
Old May 19, 2006 | 09:16 AM
Bad reactions at the line,will result in "bogging",or a lost of traction,causing excessive wheelspin,and both will increase your 60 feet time.
Good reactions,controlling the power delivery,will get you 1.8--1.9, 60 feet times.
clawhammer's Avatar
It's not reaction time
It's your 60' time. Your reaction time should be right above the 60' time on the slip, but that does not affect your 1/4 time in any way.
Old May 19, 2006 | 09:18 AM
clawhammer's Avatar
I could sit at the light for 2 seconds after it goes green, and launch perfectly. I could have a 2 second reaction time, which is horrible, but I can still have a 1.9 60' time which is very good. Reaction =/= 60'.
Old May 19, 2006 | 09:21 AM
CIVICTOS2000's Avatar
I Hope you do better than 13.5 , Good Luck..
D.
