going to hit 80,000 miles
Old Apr 17, 2010 | 12:36 PM
hybridcmk's Avatar
Thumbs up going to hit 80,000 miles
Im going to be hitting 80,000 miles soon. Is there anything i should change. Anything I should be aware of? thanks.
Old Apr 17, 2010 | 02:23 PM
Moddiction's Avatar
Former Sponsor
Just standard maintenance stuff as usual. Nothing special. Maybe a valve adjustment soon if you haven't had one and in not too long some spark plugs.
Old Apr 17, 2010 | 02:33 PM
hybridcmk's Avatar
what about injectors?
Old Apr 17, 2010 | 02:38 PM
Moddiction's Avatar
Former Sponsor
Unless they are busted no need to at all.
Old Apr 17, 2010 | 02:56 PM
hybridcmk's Avatar
ok
Old Apr 18, 2010 | 07:00 AM
shamoo's Avatar
It also depends what you've done in the past. Did you do all the "recommended" maintenance prior to the 80K?
Old Apr 18, 2010 | 11:54 AM
s2k dre's Avatar
Yea fill it up with gas and keep driving! Just adjust the valves and change fluids.
Old Apr 18, 2010 | 04:49 PM
pkolaboy's Avatar
What about your sparkplugs?
Old Apr 18, 2010 | 06:01 PM
hybridcmk's Avatar
im not sure. i bought the car in september and i only but 4k miles on it. not sure when the last time they were changed. what ones should i pick up?
Old Apr 18, 2010 | 07:50 PM
sillyboybmxer's Avatar
hell if you just bought it i would change
oil 10w-30
rear diff fluid lubrication engineers 1605 or mobil1/redline/ 75w-140
transmission-honda manual transmission fluid
serpentine(sp) belt
check the coolant level
check the brake fluid
