Got my S2000 on the rollers
Old Jun 24, 2015 | 03:25 AM
MarcS2000's Avatar
Default Got my S2000 on the rollers
There was a rolling road evening at a local performance garage and decided to take my 2000 S2000 along to see what she's got. Only engine mods are an unknown brand cold air intake system and a pair of unknown jap can exhaust backboxes.
Peak BHP was 212.99 at the wheels
Its best to listen to it through a set of headphones if you can.
Video of the first 3 runs
https://youtu.be/ISHiVpTguco
There was a problem with the rollers on the first run and showed only 80 odd bhp!
Final Run
https://youtu.be/v-WAwPw3_4I
Dyno graph
Pretty happy with the results
Old Jun 24, 2015 | 06:08 AM
MarcS2000's Avatar
Does the AFR seem normal to those in the know?
Old Jun 25, 2015 | 10:39 PM
LDfavoriteson's Avatar
I'm no expert but it looks ok. Maybe some others will chime in.
Old Jun 25, 2015 | 10:47 PM
superchargedk20's Avatar
That's one high reading dyno. Afr look a little lean in some areas but nothing crazy. The final run was good. Ur good
Old Jun 26, 2015 | 11:19 AM
Mikey81's Avatar
Looks a touch lean but not too bad, also I would say that is probably power at the flywheel not the wheels?
Old Jun 29, 2015 | 12:22 AM
MarcS2000's Avatar
This is at the wheels, have to do some calculation ourselves for the flywheel figure, but he worked it out to be 244 at the flywheel.
Old Jun 29, 2015 | 07:15 AM
matthugie's Avatar
FYI - BHP is at the flywheel, WHP is at the wheels. Semantics aside, those are some pretty strong numbers for a mostly stock car.
Old Aug 4, 2015 | 02:04 PM
steven975's Avatar
That's a great reading, for sure.
You really can't compare them too much, as some read higher than others. Mine was 191 stock, but that was on a Mustang which tends to make people cry (but over 300 after my mods).
superchargedk20
Jun 8, 2020 12:48 PM
Mrsideways
Jul 10, 2013 08:25 AM
Freshjive
Apr 6, 2009 08:53 AM
bigfecker
May 25, 2005 09:23 AM
