Grease for Clutch Fork
Old Jul 12, 2007 | 07:46 AM
billo's Avatar
Default Grease for Clutch Fork
I bled and replaced my clutch fluid about 18 months ago. At that time, I used some high temp grease to lube my clutch fork and target cup. Now I've got the metal to metal sound and feel back whenever I use the clutch pedal. Anyone have some advice on the best lube for these parts. Anyone try anti-seize?
Old Jul 12, 2007 | 07:49 AM
Stratocaster's Avatar
Honda makes a hi-temp UERA grease just for this. Your dealer stock it and it is fairly cheap. I am not sure on the spelling.
Old Jul 12, 2007 | 07:51 AM
billo's Avatar
Thx.
Old Jul 12, 2007 | 09:12 AM
jack.tsu's Avatar
*Urea
Like the stuff in your pee
edit: heres the part number 08798-9002
Old Jul 12, 2007 | 10:24 AM
oakfloor's Avatar
How did you get inside the bell housing to put grease on the clutch fork? And are you greasing the drive shaft that the throwout bearing rides on? I thought the it was not accessable without removing the whole tranny ETC. BTW I did lube up the rod and cup with redilne grease, and it helped some.
Old Aug 23, 2008 | 12:33 PM
S2KVITO's Avatar
Just Greased my Clutch fork and did the clutch bleed.I would recomend having three people one to pump, one to bleed the slave cylinder and another to fill as needed underhood. My car drives better than new no more noise in 1st from a stop, smooth shifts and engagement of my clutch def worth doing this!
Nemi
Aug 21, 2013 09:33 AM
Brndon
Mar 18, 2013 02:49 PM
realmike15
May 4, 2011 09:10 AM
Dragon Slayer
Dec 7, 2007 05:56 AM
850glt
May 11, 2004 01:00 PM
