guys with 04-07
Originally Posted by scottrunsxc,Dec 25 2006, 09:39 PM
You're doing good to hit 13's NA. High 12's? You're
some good sheet main...
Originally Posted by versionJDM,Dec 26 2006, 11:17 AM
pah-lease. i am currently running 13.5's@106 WITH a 2.2 60'! if i cut a 1.9 60' i might be able to hit high 13.3's. with as little as 4.56 gears i could EASILY hit 12.9's.
I think its totally doable.
I've seen a totally stock dodge stealth twin turbo run a 13.0 flat. A stock stealth/3000gt turbo puts down about 230awhp and weighs almost 1000lbs more than an s2000
Granted the Stealth can pull a 1.7 60 foot since its AWD, which gives it a huge advantage when it comes to ET, but the trap speed is still around 105mph.
It might take some drag radials or slicks to bust off a 12.9 but I still believe its possible.
Originally Posted by OCMusicJunkie,Dec 26 2006, 01:11 PM
If you're going to run DRs or slicks with a setup that'll put you even in the low 13s, you better do some serious work on your car's rear. Otherwise, I don't think you're going any faster than AAA can tow you.
Originally Posted by Red_Devil,Dec 26 2006, 03:28 PM
But I alway saw people say that GEARS will hurt your time because extra shift before 1/4 end, is that right
Originally Posted by versionJDM,Dec 26 2006, 03:31 PM
but if you shift fast enough you can negate the extra shift time and turn it into a lower e.t.
Originally Posted by Red_Devil,Dec 26 2006, 03:22 PM
may I know why
