Hangs slightly in first gear.......?
Old Apr 29, 2009 | 03:39 PM
roadie114's Avatar
Default Hangs slightly in first gear.......?
Anybody notice first gear hanging up or sticking a little bit intermittantly when going from first into second? I've experimented at different rev's, hot or cold, etc. and it's just completely random. Not a big deal, but not as smooth as I'd like it to be on occasion. Thx.
BTW, it's an '05 with about 60,000 miles.
Old Apr 29, 2009 | 04:43 PM
plutonium239's Avatar
Hmm, never noticed that. I have a little grief going into second from time to time but never taking it out of first.
Old Apr 29, 2009 | 05:41 PM
Project22a's Avatar
Heavy stock AP2 flywheel?
Old Apr 29, 2009 | 05:45 PM
FitzyS2k's Avatar
well my 01 if i stay in first gear IE going from stop light to stop light the tranny stays and slowly revs down to idle. i also noticed that i can't get it out of first until it gets to idle.
Old Apr 29, 2009 | 08:03 PM
roadie114's Avatar
Hmm....................never had that issue at all. Normally I can shift out of first immediately after pushing the clutch in with no problems, but occasionally it feels like it wants to "stick" in first gear for a split second before coming out. I have noticed that if you go into first at just the wrong time, it will grind when coming to a stop (5mph or so). I've found the key is to put it into first either while slowing down around 10mph, or wait until fully stopped.
I get the typical 2nd and 3rd gear issues only when cold. I've learned to shift very slow at low revs going into 2nd to avoid the grind, and shift very slow into 3rd at higher revs to avoid the extreme notchiness (only when cold).
It's nothing too problematic, I just like it to be smooth and consistent during "spirited driving."
Old Apr 29, 2009 | 09:59 PM
ahrmike's Avatar
Check your master cylinder. Also, when you clutch, try immediately pulling it out of gear . if you wait a little bit, it WILL hang up.
Old Apr 30, 2009 | 01:15 PM
roadie114's Avatar
Why is that?
cloud70
May 13, 2017 06:56 AM
superstuddc27
Aug 11, 2013 08:17 AM
Henwhee
Nov 5, 2011 03:19 PM
jal3lee
Jul 28, 2005 12:17 PM
jt4emert
Mar 29, 2005 07:52 AM
