HARDTOP HARDWARE
Does anyone know the hardware part numbers I would need for a C-Wings Hardtop? Does it need all the mounting hardware as an OEM HT? I know I would not need the defroster. Any help is appreciated.
No defroster, but you will need the seals and a bunch of other odds and ends. This is everything you need in one item. No Defrosts stuff. http://www.hardtopguy.com/store/product.ph...1&cat=92&page=1
Also you will need to have a window cut and installed in the rear. That is not an OEM part and you will need to figure it out.
When you are all done with the installation, please post what you paid to get it all installed and complete.
Fit and finish with the OEM top is first rate and it comes already painted. This is not to mention that the defroster is also included.
Unless the OEM style doesn't appeal to you, get the OEM and be done with it.
I think you'll be glad you did.
I am estimating that by the time all is complete with mine, I will have paid between $1,000 - $1,200 for all of the necessary hardware.
$600 Hardtop (Terrific Deal)
$200 OEM Driver and Passenger Side Window Seal
$150 Custom Machined Brackets
$65 Plexiglass Window (Cut to size)
$20 Plexiglass Window Seal
$50 OEM Hardtop Strikers (May not be necessary)
$15 Miscellaneous Silicone and Super Glue
$20 Lower Rear Weather Stripping
I may be able to complete everything for less than the prices noted if I am able to source a similar driver and passenger side window seal. I am also expecting bracket prices to cost less than what is posted as I am expecting there will be no welding required and no major metal bending.
I am picking up my top from paint most likely tomorrow and when everything is complete, I will post my final totals.
djeddiebear
Jul 25, 2015 04:35 PM
