Hardtop Hoist
Old Oct 17, 2005 | 10:11 AM
JonasM's Avatar
Originally Posted by meth,Oct 17 2005, 12:41 PM
why don't you guys just pay this guy to make you one.
this thing looks efficient.
Sorry, used the rest to make firewood racks....
JonasM
Old Oct 17, 2005 | 10:28 AM
DosEquis Driver's Avatar
40lbs suspended from ceiling joists isn't all that much weight in grand scheme of things, particularly if you run the mounting board or rail such that it spans several joists. The only concern I would have would be with regard to the attachment system.
FWIW, When I last checked I have about 200lbs of bicycles hanging from the garage ceiling across 6 joists over an 8 foot span, several of which are tandem bicycles weighing more than 40lbs each.
The same joists sit under a 2nd floor exercise room with a machine that has about 300lbs of lead weight.
Old Oct 17, 2005 | 11:00 AM
RyanSpaS2K's Avatar
I'll be going into concrete, so I imagine it will be fine. Anyone else ever drill into a concrete roof to mount something like this?
Old Oct 18, 2005 | 05:36 AM
mister_two's Avatar
Here's my setup. I have only used it a few times, will probably use it more this winter since I just bought snow tires. The only issue I have had is when lowering and raising it doesn't lower and rise evenly between the front and back. In order to raise/lower evenly I pull on a secondary rope.
Old Oct 18, 2005 | 07:34 AM
AusS2000's Avatar
Dynabolts will hold a wole lot more than a hardtop without even feeling it.
Old Oct 18, 2005 | 07:48 AM
FO2K's Avatar
Put a small cube of styrofoam over the rear centering mechanism. Save yourself the pain of gouging your head if you walk into it.
Old Oct 19, 2005 | 12:46 PM
Calvin's Avatar
Originally Posted by JonasM,Oct 17 2005, 08:29 AM
Jonas
Where did you get the clip?
Old Oct 19, 2005 | 04:05 PM
JonasM's Avatar
Originally Posted by Calvin,Oct 19 2005, 04:46 PM
Jonas
Good question - it was about 3 years ago...
I think it was at Sears Hardware, in the miscellaneous section. I bent them a bit for a better fit, and glued a strip of rubber to the inside. It fit nicely between the rubber and the lip of the top.
JonasM
Old Oct 19, 2005 | 04:48 PM
phatrabbitzz's Avatar
What's the point of a hoist? Why not just put it on the floor?
Old Oct 19, 2005 | 04:51 PM
For me, to free up floor space.
