hardtop noises
Old Jan 11, 2005 | 10:53 PM
CHIX RULE's Avatar
Originally Posted by dut,Jan 12 2005, 02:50 AM
- well, don't you know how to lube the rubber?
Now I could take that 2 ways
I just wanna make sure I get it on the right areas, knowing me, Id just put it everywhere to make sure Its covered!
Old Jan 11, 2005 | 10:56 PM
dut's Avatar
dut
- that'll work
Old Jan 11, 2005 | 11:18 PM
Silver9k's Avatar
ya put the lube on both sides to make sure there is no harsh rubbing
Old Jan 11, 2005 | 11:56 PM
kevsS2's Avatar
Old Jan 12, 2005 | 12:02 AM
WtbS2k's Avatar
Old Jan 12, 2005 | 03:29 AM
Boston Duce's Avatar
The next time you have the HT off, check the assembly where the rear locking levers are attached to.
Make sure the assembly is tight and you can't wiggle the bracket.
Brackets fasten to the HT body with three bolts screwed into a tapped boss under each rear B panel trim.
These are the bolts which give some adjustment 'play' during the initial install event. The bolts are round and go through the bracket which has square holes punched into it. This give the wiggle room necessary for the HT adjustment procedure.
The trim panel just snaps off exposing the bolts.
Mine were very loose, as soon as they were tightened my sqeaks and groans went away.
Regards,
BD
Old Jan 12, 2005 | 03:42 AM
Beardie's Avatar
Shinetsu is just the brand of grease that Honda provides. You can ask your dealer for it, or get some from diving shops. As long as it's silicone grease you're okay.
Note that the squeeks and groans from the rubbers is different from the thumps and bumps of a loose HT.
If your HT is thumping, follow BD's advice and you should be in good shape.
Old Jan 12, 2005 | 07:35 AM
Ooalloems2koO's Avatar
go back to softtop!
Crestys2k
Nov 3, 2015 03:19 AM
msisleman
Jan 25, 2010 11:00 AM
aaroncosbey
Oct 7, 2008 09:35 PM
smirfs2k05
May 11, 2007 07:41 AM
Lightning
Oct 31, 2006 06:48 AM
