Is it harmful to turn the AC on and off?
Old Jul 27, 2008 | 05:47 AM
Purple Haze's Avatar
Default Is it harmful to turn the AC on and off?
Hi. On days when it is hot but not extremely hot, I like to turn the AC on until the car cools off. Then when the car becomes a little too cold, I turn the AC off for a while until the car becomes too warm again.
Usually I cycle between five minutes on and five minutes off.
Is this harmful to the AC systen? Would it be better to turn the temp dial to a warmer position and leave the AC on continuously?
Old Jul 27, 2008 | 05:50 AM
Ks320's Avatar
I think you should leave it to a warmer position, not that it should break your AC, but then Honda designed the temp adjustments for you so you don't need to turn A/C on and off all the time yourself ... it's also safer as well, since you won't be fiddling with the controls every now and then
Old Jul 27, 2008 | 08:31 AM
EVAN&MONICA's Avatar
Its fine
Old Jul 27, 2008 | 08:56 AM
Rubn1out4GudLuk's Avatar
Why don't you do what I do and switch the vents from the ones up front to the ones down low by the foot well area only. By the time the air reaches you from down there it would have warmed up enough and keeps your car at a steady temp without you messing with the A/C's on & off button. Just a suggestion since it works for me.
Good Luck
Old Jul 27, 2008 | 09:53 AM
takeshi's Avatar
Meh. Mostly a matter of personal preference. I couldn't stand to fiddle with the AC controls constantly like that.
I guess it's also a bit different down here. Anything less than full blast isn't enough.
Old Jul 27, 2008 | 09:59 AM
Elistan's Avatar
No issues - the car does this iteself, actually. Pop the hood sometime and watch the AC unit - you'll see it turn off an on even if you have it turned on to full.
Old Jul 27, 2008 | 10:21 AM
craig2teg's Avatar
Dang beat me to it .
Old Jul 27, 2008 | 04:09 PM
21337R's Avatar
I wonder if we can rig some kind of climate control... that would be sweet!
Old Jul 27, 2008 | 05:39 PM
common reactor's Avatar
Originally Posted by EVAN&MONICA,Jul 27 2008, 08:31 AM
Its fine
Old Jul 27, 2008 | 06:05 PM
auto2nr1's Avatar
i don't think it is harmful if you turn the AC on and off.
