Harness mounting?
Old Dec 2, 2003 | 06:12 PM
BlueS2000Boy's Avatar
Default Harness mounting?
ok here is the deal. i just got two bride pro's. i want to put harnesses in the car to go with the seats. now i know that you should never mount them on the bottom of the seat bolts. i hve been told that the only good way to do it would be a cage with a harness bar. but i know BYS makes harness anchors. and i was thinking i would just cut slits in the plastic behind the seats where people put speakers. then i would put the anchors in that area behind the plastic mounted to the car. anyone else advice or anyone they would recomend i ask? thanks
Old Dec 2, 2003 | 08:24 PM
Slows2k's Avatar
http://forums.s2ki.com/forums/showthread.p...threadid=166623
You might wan't to check out the Racing forum for harness mounting info.
Old Dec 3, 2003 | 03:55 AM
CoralDoc's Avatar
Shoulder harness mounts must be level with your shoulder to up to 10 degrees down from horizontal. If you mount them lower than that you run a great risk of spinal compression in a frontal accident. The mounting point for your harness must be able to withstand extremely high loading, and I can't imagine how you could do it without installing an aftermarket rollbar with harness attachment points.
I also encourage you to carefully read the thread mentioned above and the linked articles in that thread to make up your own mind about what is safe on the street.
summitrider2012
Mar 2, 2016 05:28 AM
Rusler Firbrand
Apr 13, 2006 08:58 PM
kubos2k
Mar 20, 2006 12:39 AM
BlueS2000Boy
Dec 2, 2003 06:13 PM
mingster
Dec 10, 2001 12:04 AM
