Has anyone tried Spoon SS clutch line??
Originally posted by fly_S2K
Clutch pedal adjustment? I don't see how replacing the clutch line would change it, but just a thought. Any comments xviper?
He indicated that 1/2 his clutch travel is "nothing". It is possible that something goofy is happening in the bleed process. It could be a bunch of air is getting in. The bleed valve should only be "cracked" open just enough to let the fluid flow. Too much and air can get back in. Also, that's why I suggested to re-read the steps in my DIY. The valve may not be getting opened or closed at the precise moment they need to be.
Hmmm... I read the DIY again... we didn't do any of the syringe part as our object is to
bleed the air out not refresing all the fluids.
We also skipped #11 of the DIY... but we had the fluid at near "max" when we're done bleeding..
would this be a big issue?
You have a mystery indeed and I would re-iterate the bit about putting the stock line back on to see if your clutch will "come back".
blacks2k
20
Mar 6, 2007 08:44 PM
