Having a hard time checking oil... Any ideas?
Old Mar 4, 2003 | 06:06 PM
S2Kay's Avatar
Default Having a hard time checking oil... Any ideas?
This is my first oil change with my S2k and I poured 5 quarts of Mobil 1 Synthetic in and checked the dip stick but it was hard to see the oil. I'm not use to the stainless steel dip stick and I don't know where the X marks the spot. The manual says to add 5.1 quarts but does that .1 really matter? Should I have anything to worry about? Thanks for any help in advance.
Old Mar 4, 2003 | 07:19 PM
speed4tu's Avatar
First of all, you shouldn't put synthetic in on the first oil change, b/c it will not allow the engine to properly break in. You fill the oil up to the top of the top X on the dipstick.
Old Mar 4, 2003 | 07:42 PM
wanabe's Avatar
and better to slightly underfill than to slighly overfill!!
(btw, the dealer told me not to go synthetic until i had 12000 miles on the engine)
Old Mar 4, 2003 | 09:26 PM
S2Kay's Avatar
well I bought my car used and it already has 19K miles.
Old Mar 4, 2003 | 09:28 PM
S2Kay's Avatar
I'm just having a hard time seeing the oil because it's not dark enough. So I cant tell exactly where it is and it also seems that one side of the XXX is higher than the other side.
Old Mar 4, 2003 | 09:57 PM
Shadow_S2K's Avatar
Former Sponsor
I take the dip stick and lay it flat on a paper towel. Then compare he oil mark it makes on the paper towel with the markings on the dip stick. Hope that helps
Old Mar 4, 2003 | 10:11 PM
PWRMKR's Avatar
pull it out. wipe it off dry. put it back in. count to three. pull in out and hold it upside down. the oil should form a drop on the dip stick, dip stick.
Good luck.
Old Mar 4, 2003 | 11:10 PM
Kwando's Avatar
new oil is sometimes hard to read. Lay it on a paper towel.
Old Mar 5, 2003 | 04:56 AM
tigerfan's Avatar
I thought our cars required 5.9 not 5.1? Am I wrong on this????
Old Mar 5, 2003 | 05:06 AM
dlq04's Avatar
[QUOTE]Originally posted by tigerfan
[B]I thought our cars required 5.9 not 5.1?
