Having a hard time checking oil... Any ideas?
Old Mar 5, 2003 | 06:18 AM
MacGyver's Avatar
You can run without issue with 5 quarts, so if it's really hard to read I'll take it for a spin around the block. That short drive is more than enough to mix up the oil and make it dirty overall. Check the driver's side of the stick as that seems to be more accurate. I slightly tilt my car towards the drain to get as much oil as possible. In the end, I end up putting in 5.5 quarts each time.
Old Mar 5, 2003 | 07:35 AM
Destiny2002's Avatar
Maybe use royal purple oil?
Old Mar 5, 2003 | 10:33 AM
XLER8R's Avatar
Originally posted by S2Kay
checked the dip stick but it was hard to see the oil.
I'm glad I am not the only one with this problem. I thought it was just old eyes. I also turn the dip stick upside down, which allows it to bead up a bit.
Old Mar 5, 2003 | 10:57 AM
tigerfan's Avatar
[QUOTE]Originally posted by dlq04
[B]
Yes.
Old Mar 5, 2003 | 11:18 AM
calpilot7's Avatar
Banned
Originally posted by wanabe
and better to slightly underfill than to slighly overfill!!
(btw, the dealer told me not to go synthetic until i had 12000 miles on the engine)
The dealer also told me that I needed to only use regular unleaded gas in the S2000....I do not put to much faith in what the dealer says. I know what kind of oil is used to lubricate turbojet engines and it is not an "organic" oil. Synthetic is used as it is much more thermal resistant to breakdown and retains it's lubrication properties longer under high temperature and shear stress levels as compared to the organic stuff. While the S2000 is not a turbine engine it is highly stressed as auto engines go and would benefit from the same properties that make synthetic oil such great jet engine lubricators. I will change over to synthetic at 7500 miles and then it's synthetic every 7500 after.
Old Mar 5, 2003 | 11:58 AM
xviper's Avatar
If you hold the stick up in a light source (natural or artificial) and move it till the oil glistens, you'll see where it stops and starts. I've never had a problem reading the level.
Old Mar 5, 2003 | 12:48 PM
[QUOTE]Originally posted by xviper
[B]If you hold the stick up in a light source (natural or artificial) and move it till the oil glistens, you'll see where it stops and starts.
Old Mar 5, 2003 | 01:16 PM
dlq04's Avatar
[QUOTE]Originally posted by tigerfan
[B]
mmm...I bought my car without a manual so to check how much oil to put in I checked the Honda webside and it says Crankcase:5.9 qts.
CoralDoc
Mar 27, 2018 01:01 PM
kentarou
Apr 17, 2006 06:02 AM
SLAPMYFRO
Jan 22, 2003 03:40 PM
GundamZ
Aug 7, 2002 12:17 AM
MDS2K
Mar 26, 2001 05:19 AM
