Headlight Adjustment
Originally Posted by Kodokan_4,Jun 10 2003, 04:40 PM
4Motto-
First of all, my post says "service manual", I believe you are looking in the owner's manual.
Second- of course the adjusting holes are there! You need to take your time, and use a flashlight to look into the holes to see the adjusters. I also mentioned that you need a 12 inch screwdriver- that means the adjusters are way in there.
Third, all you need to do is look in the website library, all of the info, including pics are there.
https://www.s2ki.com/article/articleview/39/1/29/
Fourth, it sounds like nothing is wrong with your beam pattern. You might want to begin reading more about the car, before you start changing things.
Sometimes it's difficult to find the info, but it's all here.
-Pete
-Pete
You don't need a looong screw driver with the appropriate Phillips head. You can do it with a 8mm (or maybe 9mm?) hex wrench. You need to reach down a bit. For the driver side, you need to take out the plastic cooler reservoir, which just comes off.
I believe I was able to find the pics here or somewhere on the web.
and didn't have much time to spend on doing the homework.
