Headlilght Adjust
Old Oct 13, 2005 | 04:29 AM
RoaringVtec's Avatar
Default Headlilght Adjust
I know there are several threads about headlight adjustment and i've read several i still need to know if when looking at the beam pattern, is it suppose to be a straight line from left to right or with a jump in the middle
Straight Line
__________________________________________________ ___________
Bump
______________________________/------------------------------------------
Mine has the bump and i can't seem to get it to even out after i dropped the car.
Old Oct 13, 2005 | 05:00 AM
50FEE's Avatar
if it makes you feel any better... mine has the bump too
Old Oct 13, 2005 | 05:02 AM
eepr5's Avatar
the bump is part of the actual HID beampattern. cover up one lens and the bump will still be there it can't be adjusted. something to do with being high on one side to show signs, but low on the other to not blind oncoming traffic. as for aligning the two beams, i think you just make the low sides of each beam even.
Old Oct 13, 2005 | 08:08 AM
PrimoGen's Avatar
^^^^^^ what he said perfectly normal and designed that way
Old Oct 13, 2005 | 08:26 AM
jlstyle82's Avatar
its designed to be bumped.
Old Oct 13, 2005 | 09:26 AM
Thanks alot guys...
Old Oct 13, 2005 | 11:35 AM
hope2owns2k's Avatar
I'm by no means trying to hi-jack your thread, but, I have a really stupid/quick question, and if I had an s2k, I'd go out and answer my question for myself
But, I'm wondering if any of you know if your HIDs stay on when you turn your brights on?
Thanks
Adam
Old Oct 13, 2005 | 11:53 AM
Kodokan_4's Avatar
Here you go, homie:
Perfectly flat on the right and left, with the elevation in the center. This keeps the beams out of the eyes of oncoming traffic.
Seriously- GET A FACTORY SERVICE MANUAL.
All the details are there, like how far to be away from the wall when adjusting, and how high the top of the pattern should be from the ground. I think it was 25ft and 19.5 inches, but it's been a long time since I've done it, so I could be wrong.
Good Luck, and don't forget the extra-long Phillips head!
-Pete
dynimite53
Socal Swap Meet
30
Nov 8, 2010 01:14 PM
CapoArgentino
Socal Swap Meet
Jun 4, 2010 11:46 AM
gusrock77
Socal Swap Meet
Sep 30, 2009 11:00 AM
