Heat Shield Gasket
Old Mar 14, 2006 | 04:08 PM
batikan's Avatar
Default Heat Shield Gasket
How hard is it to install this?? Most of the shops charge $250-$300 for a $55 part. Is there a DIY on it??
Old Mar 14, 2006 | 04:56 PM
xviper's Avatar
I understand it's a mofo to install.
https://www.s2ki.com/forums/index.php?showtopic=33147
Old Mar 14, 2006 | 07:51 PM
pwrofdrm's Avatar
It's time consuming and kind of a PITA. Took me and two friends 3 hours to do on my S. The braces underneath the intake manifold need to be removed in order to take it off, they are a bitch to get at! At the end I removed mine in case I ever have to do it again.
I would charge $200 to do it if I were to do it again.
Old Mar 14, 2006 | 08:28 PM
latinvip11's Avatar
To be honest... It was really a bitch to actually do. It took me about 2 and half hours. And those braces that hold the manifold they don't even tell you about them and the one intake manifold bolt thats hidden behind the what i belive was/is the coolant temp sensor, thats a bitch.
I wouldn't charge so much though to do it. id say about $150 and a 24 pack of miller lite.
Old Mar 15, 2006 | 06:10 PM
spider2k's Avatar
Active Streak: 30 Days
its not that bad once you know some tricks. you dont need the long freaky extensions and swivels if you just remove the alternator and idler pulley/bracket. it opens up the area under the manifold so you can get in there.
Old Mar 15, 2006 | 06:20 PM
Vladimir L's Avatar
I'm getting this done too but only because the head will be off the car. Recently bent a few valves.
philipminge
Jun 22, 2014 10:22 PM
HARDtoTOP
May 13, 2008 09:43 AM
RIDGERCR
Apr 7, 2007 01:40 PM
BlackBulletS2K
Aug 17, 2006 07:03 AM
Prolene
Apr 17, 2002 11:10 AM
