Heel-Toe
Originally Posted by RED MX5,Oct 4 2007, 07:26 AM
Hahaha, haven't we discussed almost everything about the car at least a few times in the past?
I'm going to have to get out and try these techniques to appreciate them so the descriptions are definitely helping.
Originally Posted by MikeyCB,Oct 4 2007, 08:56 AM
Sorry if we're redoing this, we'll come up with some new stuff to talk about soon
Originally Posted by RED MX5,Oct 4 2007, 09:25 AM
because I was taught to get the shifting done before turning in whenever possible.
Originally Posted by __redruM,Oct 4 2007, 10:49 AM
Also there's something I'm missing here. Double clutching on an upshift gets the input shaft up to speed. But on a downshift, wouldn't the input shaft have to slow down? So a double clutch blip on a downshift would slow the shift... Maybe some googling would help.
on a downshift, you get the opposite. your engine speed after the shift will be higher (thus blipping the throttle to rev match). double clutching lets you rev match the transmission input shaft to the desired engine speed which will both be higher than before the downshift.
Red_MX5, i also don't see how double clutching can transfer power from the input to the output shaft, unless we're talking about friction. so i guess the drivetrain (or more specifically transmission) loss is transferred to the output shaft? it couldn't be very much , because if you rev the car in neutral you won't get anywhere (but i guess static friction and inertia is much more to overcome than kinetic friction). i don't know, that's the only thing i can think of.
Great article that explains the basics of heel-and-toe & rev-matching:
http://www.edmunds.com/advice/youngdrivers...93/article.html
And basics of driving a manual tranny:
http://www.edmunds.com/advice/youngdrivers...20/article.html
I found this very true:
"Nowadays, driving a stick shift has become a lost art form as more and more people opt for the convenience and ease of an automatic. Unfortunate, considering how fun driving a manual transmission car is; you really get a sense of man-and-machine symbiosis when you master the manual transmission. And there's nothing like some good heel-toe action." -- Edmunds.com
Originally Posted by Ks320,Oct 4 2007, 01:56 PM
^^ I don't even double clutch on the S2000 unless I'm shifting down to 1st gear. I just roll through each gear when I need to downshift ...
On an upshift, the engine speed drops after the shift, so the transmission input shaft need to be slowed to match the new engine speed. Double clutching doesn't help because the transmission input side slows naturally and isn't fighting the synchro's attempts to slow it down. On a downshift, the engine speed will be higher after the shift, so the input shaft of the trans has to be accelerated to the higher speed, either by the synchros, or by engine speed and a double clutch.
The required action for a double clutch is the same as for a rev match. For an upshift you don't need to worry because things slow down naturally, but on a downshift it takes a substantial stab at the throttle to get the revs up to match engine speed to the lower gear ratio.
Does that make more sense?
