Heel&Toe, Double-Clutching and Neutral Rev
It is commonly known that double-clutching and heel & toeing are techniques that will help prolong your synchros and clutch. Both these techniques require the driver to blip the throttle (rev in neutral). However, revving in neutral is widely regarded as bad for the engine. See the conflict? What gives?
Double clutching is unnecessary on a car with synchronizers, that is why they exist. Heel-toe may prolong the life of the clutch presuming it is done properly. Unfortunately I've never heard anywhere that revving in neutral is bad for the engine. It's the only way you should rev the engine if you are going to do it at all. The worst thing that can happen is neutral is that you hit the rev limiter, and heel-toe (done properly) will not do that.
Double-clutching is useless in modern standard shift cars. Revving the engine during the transition is called Rev-match commonly known as downshift rev-match. If you don't rev-match, the car will rev up when you downshift and give you a big jerk depending on the RPM. And No, there is not conflict.
Originally Posted by ROTFLMAO,Nov 19 2007, 09:54 AM
Isn't it not uncommon to reach the rev limiter (or near it) when heel & toeing?
