Help! Car is dead, real rough idle!
Old Jul 15, 2007 | 01:46 AM
Boostedtaco's Avatar
Smile Help! Car is dead, real rough idle!
Well my car is dead, lemme run down what happend.
it's a 02' with 109k miles, intake, test pipe, comptech ESM and 255 fuel pump.
I'm cruising at 70 mph, and the Check Engine Light flashes, I feel the car loose power then it dies.
On the shoulder, i try to start it but it only cranks and never fires. The CEL is not on so i try to pull the code with a obd 2 reader. No codes come back. I check the vacuum lines, battery and fuel pump. So i know i have fuel. Check the fuses and the 15 amp fuse Ignition or Ignitor is blown. (3rd from the bottom left hand side)
Replace the fuse, and the car starts with a REAL REAL bad idle, like it on 2 cylindars or something and i kill it immeditally and have the car towed home.
Ok, what do i do now? Check coil packs? Ignitor? Crank sensor? Or do i need to tow it to honda now....
Also what could cause the fuse to pop?
Old Jul 15, 2007 | 04:45 AM
gots2000's Avatar
I had the same problem besides my check engine light didnt turn on. How much fuel do you have? I had 2 bars left and my gas light was on. I put 5 gallons in it and it fired right back up.
Old Jul 15, 2007 | 05:44 AM
LuckyStar's Avatar
Coils and Ignitor would be the next place to check.
Specifically look to see if any of the wires have rubbed on something or if anything touching a ground.
A Digital Multimeter will really be useful to narrow down where the problem is coming from.
Probably need a service manual so you can look up what the proper voltage readings are.
I actually havn't done a lot of research on the S's coil pack system, but many systems use 2 ignitors and 4 coils. If 1 ignitor goes then you would lose 2 cylinders.
I have seen 4 cylinders idle on 3 cylinders rough, but never on 2
Old Jul 15, 2007 | 06:08 AM
CKit's Avatar
Look at the spark plugs.
Old Jul 15, 2007 | 08:24 AM
negcamber's Avatar
Any over-revs in the car's past?
Old Jul 15, 2007 | 08:39 AM
viets2k's Avatar
Need me come over to check it out? Sunday is my cruising day so i don't mind driving up to Addison. LMK. btw, me damn phone is dead(drop the dang thing in the water!)....so just pm me and let me know.
Old Jul 15, 2007 | 09:53 AM
I have half a tank. Wish it was something simple as that.
Old Jul 15, 2007 | 09:56 AM
I had a over-rev about 60k miles ago...
Old Jul 15, 2007 | 10:07 AM
negcamber's Avatar
Then you may have dropped a valve. Check your compression. Once weakened by an over-rev, the retainers can develop cracks over time and let go even years after the over-rev happened.
What you are describing sounds very similar to a dropped valve.
Old Jul 15, 2007 | 10:28 AM
great, dropped valve. Pretty much a new head and short block i'm guessing.
geez....well i'll find out after the compression check. Stay tuned for upcoming fire sale!!!
