, help, Does s2000 have traction control?
Old Jan 9, 2004 | 03:39 PM
hoangt7's Avatar
Default , help, Does s2000 have traction control?
My 03 s2000 has a little bit over 15k milage now, and the maintanaice light is on, i have already changed the oil. but recently i've noticed the rear goes out of the control (well not really that bad) when turning 90 degree, even when turning slow, thank u
Old Jan 9, 2004 | 03:51 PM
ERicincal's Avatar
no traction control on my car- so I assume the car doesnt have it. I was just reading about the spring spacers- you might want to check to see if yours are still in. If they are, then you need to remove them.
Old Jan 9, 2004 | 04:07 PM
1Fast99Si's Avatar
I bet its rear Potenzas that are near bald. 15K on original tires? If so, change them puppies in the rear at least.
Old Jan 9, 2004 | 04:10 PM
jankemi's Avatar
You control the traction the old fashoned way - with your right foot.
The search button should help you find out more about the maintenance light.
--Mike
Old Jan 9, 2004 | 04:16 PM
RazorV3's Avatar
either your tires are in bad shape OR the dealer didn't take out your spring spacers during PDI. take it in and have them double check that, there are so many s2k's on the road with spring spacers still installed .
Old Jan 9, 2004 | 05:10 PM
hoangt7's Avatar
i'm sorry for my lack of knowledge but what is PDI and Spring spacer?
Old Jan 9, 2004 | 05:17 PM
Johnny--2K's Avatar
PDI is the safety inspection they do before the car is delivered, and the spring spacers are put in at the factory to raise the car so it does not scrape when loading/unloading from the truck/boat!
HTH,
John
Old Jan 9, 2004 | 05:43 PM
MyHieu's Avatar
is your tires!
Old Jan 9, 2004 | 05:57 PM
soundzero's Avatar
No tracktion control but has best set up. Front engine, rwd with LSD.
you need new tires.
Old Jan 9, 2004 | 06:05 PM
s2ksimon's Avatar
tires or spring spacers indeed
