Help on installing Cusco 4 pt. roll cage...
Old Feb 26, 2005 | 04:38 AM
FIZZ-AP1's Avatar
Default Help on installing Cusco 4 pt. roll cage...
I just got a Cusco 4 pt. roll cage, but the instructions are all in Japanese. Does anyone have any idea on how to install it? Do i need to remove any panels etc., and where does it bolt to? Any help is appreciated. I'm probably gonna wind up bringing it to my body shop, but i figured i'd check on here 1st. thanks
Old Feb 26, 2005 | 10:38 AM
AJ PwR's Avatar
I have the ALEX 4pt cage which is pretty similar that you have. Here's some pics for the installation and I hope this would help. Here's just the steps that you have to do .
1) remove the seats
2) remove all the panels including the loop, reartray panel and the center rear console where you can access the follr base behind.
3) put in the cage and align it. Use marker to make the spot that you have to drill. Measure the sides with the panel to drill hole to fit under the cage.
4) carpet has to be cut to fit the cage mounting for the front 2 pts.
Good luck
Thanks,
Ben
Old Feb 26, 2005 | 10:53 AM
turbo_pwr's Avatar
That's pretty cool how you painted the front part white and left the back the Cusco blue.
EnVme
Jul 15, 2014 04:01 PM
S2000Shifter
Sep 18, 2008 01:29 PM
ApexMotorPro
Jun 22, 2006 02:10 PM
ApexMotorPro
Jun 21, 2006 06:58 PM
s2ksteve
Jun 3, 2006 02:01 PM
