help with my new S2000
Old Feb 13, 2007 | 07:00 AM
kidjetta's Avatar
Default help with my new S2000
Hey guys i just got my 00 honda s2000 with 50k miles with it, what should i do first, oil change? what other things should i check for? transmission fluid, please help me, your info will be greatly appreciated
Old Feb 13, 2007 | 07:13 AM
Pok's Avatar
Pok
I would change the oil, engine and transmission, check the air filter, pollen filter etc.
Old Feb 13, 2007 | 07:18 AM
Nate03's Avatar
I'd also do the differential oil and if it were me I'd like a fresh start valve inspection & adjustment...(makes that engine even 'brighter')...also wash & wax, shinetsu grease on all the rubber seals...
check for spring spacers..... j/k
good luck & drive safe & enjoy... get used to the thing before you drive it very hard.
Old Feb 13, 2007 | 07:37 AM
novatemp03's Avatar
Change oil
change transmission fluid
change rear diff fluid
check air filter
check pollen filter
If its been raced hard consider changing brake fluid.
silicon grease to rubber boots.
check brakes and rotors
check the cluch fluid.
check the radiator fluid
check the fan belt for wear.
clean and check car for wear , soft top, hoses etc.
check the tires
have fun.
Old Feb 13, 2007 | 08:19 AM
tadas's Avatar
off the topic a bit, but i was curiuos if s2000 steering wheel is adjustable?
Old Feb 13, 2007 | 08:23 AM
smurf2k's Avatar
negative on last question
Old Feb 13, 2007 | 09:03 AM
gomarlins3's Avatar
Originally Posted by novatemp03,Feb 13 2007, 09:37 AM
Change oil
check air filter
check pollen filter
Good list, but I would CHANGE the clutch and brake fluid so you know it's been done and when it was done. You are under there anyway, you might as well.
Old Feb 13, 2007 | 09:23 AM
Nate03's Avatar
Originally Posted by novatemp03,Feb 13 2007, 11:37 AM
Change oil
check air filter
check pollen filter
check the tires
have fun.
good check list.
I'd inspect/adjust the valves on 50K miles S2000.
have fun. <----my favorite item to check.
Old Feb 13, 2007 | 09:30 AM
beanolo's Avatar
inspect under both seats for coins
Old Feb 13, 2007 | 09:34 AM
fltsfshr's Avatar
Look in the secret compartment.
You might find maintenance records.
fltsfshr
