HELP!!!!!!! My V-Tech is not working
Old Jun 28, 2003 | 04:39 PM
Cole_19's Avatar
Default HELP!!!!!!! My V-Tech is not working
Everytime i get my car up to 6000 rpm's it just sounds bogged down and it jerks very hard. Does someone have an idea what it is so i know what i am dealing with when i take it to the dealer!!! Thanks in Advance!!
Old Jun 28, 2003 | 04:49 PM
1Fast99Si's Avatar
Please, its VTEC. Sounds like your car is not warmed up when ur hitting 6K rpm's. The temp. guage needs 3 bars to exceed 6,000 rpm's. Good luck.
Old Jun 28, 2003 | 05:00 PM
CG's Avatar
CG
If the car is low on oil it won't VTEC. Check your oil or you may be buying an engine. 1Fast99Si is correct also.
Old Jun 28, 2003 | 05:24 PM
Silvers808's Avatar
VTECH? take it back to that store you bought it at. those phones can be troublesome some times.
now if you were talking about vtec and your s2000, you need to allow it to warm up first
Old Jun 28, 2003 | 05:40 PM
Ace10's Avatar
i agree whole-heartedly with all of the preceeding statements.
Old Jun 28, 2003 | 09:49 PM
Cole_19's Avatar
Hey I know some times I am a freakin IDIOT!!!! Sorry for the misprint it is VTEC. And it is running fine but it just does that in that rpm range. And it also has enough oil!!!!!!!!!!!!
Old Jun 28, 2003 | 09:55 PM
geminiS2's Avatar
is ur motor heated up like 3 bars on the temp gauge
Old Jun 28, 2003 | 10:03 PM
Cole_19's Avatar
yes my temp guage is at 3 bars
Old Jun 29, 2003 | 12:14 AM
docofmind's Avatar
3 possible suspects, two have already been mentioned.
1. Engine Temp
2. Low oil
3. Faulty Vtec silinoid
Old Jun 29, 2003 | 04:18 AM
Barry in Wyoming's Avatar
See if you've got a dipstick in your F20C. Many of the S2000 engines came with one as standard equipment. If you've got one, check it and let us know what it says.
If your engine has a normal oil level and if your engine still doesn't reach 9000 rpm in a smooth manner when warm, you've got a more complicated problem. The VTEC solenoid, the MAP sensor, aftermarket headers, bad fuel and many, many other factors will cause the car to avoid switching to the higher rpm cam profile.
Is your "check engine" light on? Is it flashing?
