HELP!!!!!!! My V-Tech is not working
Everytime i get my car up to 6000 rpm's it just sounds bogged down and it jerks very hard. Does someone have an idea what it is so i know what i am dealing with when i take it to the dealer!!! Thanks in Advance!!
Hey I know some times I am a freakin IDIOT!!!! Sorry for the misprint it is VTEC. And it is running fine but it just does that in that rpm range. And it also has enough oil!!!!!!!!!!!!
See if you've got a dipstick in your F20C. Many of the S2000 engines came with one as standard equipment. If you've got one, check it and let us know what it says.
If your engine has a normal oil level and if your engine still doesn't reach 9000 rpm in a smooth manner when warm, you've got a more complicated problem. The VTEC solenoid, the MAP sensor, aftermarket headers, bad fuel and many, many other factors will cause the car to avoid switching to the higher rpm cam profile.
Is your "check engine" light on? Is it flashing?
