HELP: Need to find out the correct way to get my passenger seat out
To make a long story short....I gotta clean under the seat. I had a bottle with a protein shake under there....forgot it was there...well it leaked...and it smells like $hit. I need to get the seat out...so I can get all the carpet out. I don't want to take the bolts off the rails if possible. Someone know how to do this? Thanks.
but dont' you have to put some kind of "sealent" or thread lock back in when you are done for safety reasons?? I'm just guessing....that is what i had heard, thanks for your help.
Yeah, I don't know either....that is why I wanted to find out. I had just heard somethings for safety reasons you need to put thread lock back on the bolts.
hecash,
just for your info, instead of re-posting, you can just edit your original post by clicking on the edit/delete icon in the upper right portion of your original post. Don't ask me how I know this, but I've used it several times to correct my original posts. I've found it's quicker, easier, and saves the embarrassment of a re-post.
Hopefully this is new info that I thought you might like to know.
after the re-install, did any of you experience a problem with the 'pins' from the locking mechanism not aligning properly with the rails?
the reason i ask is i recently had the seatbelt recall done on my car. the drivers seat does not 'lock' into place unless i pull myself forward using the steering wheel . . . at that point the pins lock into place (audible). i brought the car back, the dealer indicated that the bolts were 'torqued' to factory specifications and that this was common. any thoughts?
any input would be appreciated.
regards,
rugby
regards,
rugby
