help on painted blinkers and parking lights
Originally posted by 03s2kman
the question im asking is how should i paint the bulbs to hide the amber. and which paint should be used on smoked diffusers?
I think I was first to do this, around two and a half years ago.
It's simple - just spray a thin coat of silver paint over the lens, around 10 secs of spraying per bulb is sufficient. If you find it is still a little orange then spray some more on. The bulb doesn't need to be perfect as you can't see the detail inside the lens..
The trick is not to spray too much such that you lose a lot of brightness from the bulb. If you do overspray though then simply use paint solvent (turps) to clean it off and start again.
Total cost - $2 for spray can, total effort - around 15 minutes for 4 bulbs.
Here's something that w1ngman wrote up: https://www.s2ki.com/forums/showthread.php?...threadid=139011
Enjoy!
AOK
Mar 25, 2004 04:36 PM
S2002
Feb 11, 2003 05:27 PM
