HELP! Pistons are colliding in Engine!
Old Jan 24, 2007 | 06:28 AM
AssassinJN's Avatar
I may not know a whole lot about issues with engine internals, but 2 years sounds like an awful long time. Not to mention the OP said that the noise starts 2-3k miles after an oil change, I would think a dropped valve would have to make noise all the time.
Old Jan 24, 2007 | 06:44 AM
Jsy622's Avatar
Still waiting on the dealer to call me..They are taking apart the engine now.
Old Jan 24, 2007 | 07:08 AM
vishnus11's Avatar
If somthing was rattling for 2 years and the car still ran, then I'm inclined to think its not a valve retainer. A wild guess would be the timing chain tensioner, or maybe a rod bearing?
Old Jan 24, 2007 | 09:35 AM
Empedocles99's Avatar
Originally Posted by Jsy622,Jan 23 2007, 06:40 PM
whenever I come within 2-3 thousand miles from a oil change
Does this mean that you are running low on oil? Are you keeping the oil full? This car is known to consume oil up to and sometimes beyond 1 quart per few thousand miles. Engines low on oil can make the sound that you are referring to, and if this is the cause of the engine failure, you're not going to have an easy time convincing any warranty to pay for repairs.
OverBooster's Avatar
Dealerships will always say the warranty may or may not cover the problem. They cannot possibly tell you over the phone that it is covered until they know exactly what the problem is. This is standard procedure. For it not to be covered, they will have to prove to you that something not covered under the warranty caused the damage. Best of luck to you.
Old Jan 24, 2007 | 12:08 PM
SheDrivesIt's Avatar
Mmmm, not really. The car is not covered under Honda OEM warranty. I am assuming it is Honda Care. No need to jump to conclusions, though. Let's see what the dealer says.
Old Jan 24, 2007 | 12:16 PM
Jsmply's Avatar
I'm wondering if its just noisy valves or injectors? 2 years is a LONG time for something major to be hitting. Keep us posted! Don't worry, if its not something owner cause then you can fight them to cover it, we will help so keep us posted.
Old Jan 24, 2007 | 12:42 PM
Jsy622's Avatar
I have the extended warranty..Is that different from honda care?
Old Jan 24, 2007 | 12:52 PM
SILAP1's Avatar
make the warranty cover it just keep on them they can make it work. alot of aftermarket warranties cover powertrain or bumper to bumper . so u said the noise only starts when you are near an oil change correct
jonner
Aug 21, 2010 02:33 AM
Pointblank
42
Jun 2, 2009 11:14 AM
Jsy622
Jun 8, 2007 07:51 PM
Jsy622
Jan 23, 2007 05:39 PM
