HELP Please!!! Autoloc install gone very bery bad.
Old Aug 2, 2003 | 10:46 AM
LostWaffle's Avatar
Default HELP Please!!! Autoloc install gone very bery bad.
I tried to install the autoloc this morning. I only installed in the drivers side door. When I tested it, my passenger window would still work, but my drivers window did not work at all in any direction.
When the passenger window still worked, the I had the red wire from the autoloc connected to the green-white wire on the big gray connector.
I then detached the red wire and connected it to the green-white wire that leads to the motor. (ie..the other half of the green-white wire)
With that combination, none of my windows worked. So then I switched it back thinking at least I could have the passenger window work.
However, even when I switched it back, none of them worked!
I don't know what's wrong. My car is sitting outside with both windows down, in a not so great neighborhood.
Please help me fix it?
Old Aug 2, 2003 | 11:10 AM
LostWaffle's Avatar
Update.
I got the passenger windor working again. There was a bad connection in one of my wire splices.
However, the drivers side window still does not work.
I feel like there's no power going to it. I don't hear a motor when I push the button.
Any thoughts?>
Old Aug 2, 2003 | 11:18 AM
LostWaffle's Avatar
Where should the red wire from the autloc unit be connected?
Old Aug 2, 2003 | 11:55 AM
LT'S S2K's Avatar
1st: PM emc2 and/or cornfish (I think that was his name).
2nd: check your fuses, all of them. I did something similar awhile back and after replacing the fuse w/ a given spare the windows worked again. Check under the steering wheel fuse box and both of the fuse boxes in the engine bay.
Good luck.
sexysilvers2000
Sep 4, 2018 04:01 PM
dylanrush
Nov 12, 2013 12:13 PM
cinaibur
Aug 3, 2011 05:56 AM
nazaracing
Dec 27, 2007 08:30 PM
rai
Dec 12, 2005 02:25 PM
