Help removing rick's steering wheel badge...
Old Mar 23, 2003 | 03:09 PM
LordMagnet's Avatar
Default Help removing rick's steering wheel badge...
I removed the badge, but what can i use to remove the cement crap left on the steering wheel? i emailed rick a few weeks ago, but haven't recieved a reply back. can anyone help? thanks.
Old Mar 23, 2003 | 03:16 PM
Stratocaster's Avatar
Whatever you used to "glue" it into place, should have a recomended solvent listed on the package. What did you use?
Old Mar 23, 2003 | 03:19 PM
LordMagnet's Avatar
i used contact cement.
Old Mar 23, 2003 | 03:37 PM
Contact cement should be removable with paint thinner. Note: read the label, it has cleanup direction on it. Mine has thinner, so I assume your does too.
Old Mar 23, 2003 | 03:54 PM
Rick Hesel's Avatar
Former Sponsor
Stratocaster has it right. Lacquer thinner should work too. But before using any solvent, try it out on a small hidden area first.
Usually the contact cement also be removed by rubbing vigoroulsy and repeatedly with a small piece of cloth or even your fingers. It does not stick very well to vinyl.
Bram
Sep 10, 2007 07:37 AM
Sik -S
Mar 18, 2006 06:20 PM
03s2kman
Jul 30, 2003 03:14 AM
SaNgO5
May 14, 2003 09:37 PM
Pixsurguy
Apr 19, 2002 09:48 PM
