Help with service bulletin, please!
Old Oct 19, 2010 | 09:54 PM
GrandMasterKhan's Avatar
I can check it tomorrow when i go into work.
Old Oct 20, 2010 | 03:01 AM
gofast182's Avatar
Old Oct 20, 2010 | 09:51 AM
Service Bulletin
© 2007 American Honda Motor Co., Inc. – All Rights Reserved ATB 37559 (0708) 1 of 1
CUSTOMER INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment, and training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an authorized Honda automobile dealer.
August 3, 2007
07-046
Applies To: 2006 S2000 – ALL
2007 S2000 – From VIN JHMAP2...7S000001 thru JHMAP2...7S003235
MIL Comes On With DTC P0600
SYMPTOM
The MIL comes on with DTC P0600 (serial communication link malfunction).
PROBABLE CAUSE
When the ignition switch is on for about 4 or more hours (engine running or not), the ECM can misinterpret the serial communication signal and set DTC P0600.
CORRECTIVE ACTION
Update the PGM-FI software with the HDS.
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 1255A2
Flat Rate Time: 0.3 hour
Failed Part: P/N 37820-PZX-A12
H/C 8582181
Defect Code: 03214
Symptom Code: 03203
Template ID: 07-046A
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a decision, before starting work.
SOFTWARE INFORMATION
HDS Software Version: 2.009.007 or later.
NOTE: An incorrect HDS software version may indicate that the vehicle does not need an update. The updated PGM-FI software program ID and P/N is shown below. If this, or a later program ID, is the Current Program ID displayed during the update, the software for this service bulletin is already installed.
REPAIR PROCEDURE
Update the PGM-FI software with the HDS and software version 2.009.007 or later. Refer to Service Bulletin 01-023, Updating Control Units/Modules.
Updated Program ID P/N
ZXA070 37805-PZX-A07
Old Oct 20, 2010 | 12:25 PM
gofast182's Avatar
GrandMasterKhan you are the man!!! Thank you so much!!! That was just in time for me to return the call from the service department saying there is no bulletin and that I need to leave the car for 4 hours for diagnosis.
I gave them 07-046 and told them I'll bring the text with me. Also the dude who picked up the phone seemed to remember a software update for the S.
Again, thank you!
gofast182
Oct 20, 2010 12:47 PM
ralper
Jan 4, 2005 03:07 AM
panykus
Nov 5, 2002 08:32 PM
panykus
Nov 5, 2002 05:45 PM
golfnut311
Nov 13, 2001 11:40 AM
