Help with turn signal and roof problems!!!!
I just referred a friend of mine with a 2003 S2000 to a stereo shop. Upon having a complete system installed the top won't go down and neither the turn signals nor hazard lights are working. I checked the interior turn signal fuse and a bunch of others and they are all in perfect condition. Does anyone have any idea what the problem might be, before we take it back to the shop?
Thanks
Thanks
Sounds like you need to use a more thorough installation technician
Since both the top and hazard lights don't work, I bet that their repsective connectors were not reconnected when the center console was reinstalled.
As for the turn signals, I hope that they are in the same circuit as tha hazard lights, otherwise there may be an issue with disconnected connectors or broken wires under the dash.
It should be an easy fix, and one that you can do yourself - just search for instructions on removing/replaceing the center console.
.Since both the top and hazard lights don't work, I bet that their repsective connectors were not reconnected when the center console was reinstalled.
ThaxOne
May 23, 2012 05:02 AM
macdaddies911
Mar 14, 2012 12:37 PM
