Hazard not working
Old Jan 19, 2013 | 05:22 PM
S2K9grand's Avatar
Default Hazard not working
So today I regreased the shifter. After doing so and installing every thing the way it came out my hazard lights do not work. The turn signal do just not the hazard. If I have the turn siginal on and turn on the Harvard the turn sig stop working.... Wtf can anyone help me out here?????
Old Jan 19, 2013 | 05:25 PM
humbucker87's Avatar
Maybe you forgot to plug back in the connector on the underside of the center console? Does your top down switch work?
Old Jan 19, 2013 | 05:26 PM
S2K9grand's Avatar
Yes it does and it is plugged back in I cleaned the connector wit q tips to
Old Jan 19, 2013 | 05:29 PM
That's really odd. This thread is almost the exact opposite of what you're seeing: https://www.s2ki.com/s2000/topic/525...opped-working/
Maybe the button is internally stuck somehow.
Old Jan 19, 2013 | 06:02 PM
S2K9grand's Avatar
Thanks for the fast reply
Old Jan 20, 2013 | 07:13 AM
S2K9grand's Avatar
Anyone else have tips or ideas on how to fix this problem????
Old Jan 20, 2013 | 08:24 AM
mlc's Avatar
mlc
I would take the console off and check to make sure you didn't pinch one of the wires and look everything over.
Obviously you messed something up when you either took it off or put it back together.
Old Jan 21, 2013 | 08:21 AM
Clemsons2k's Avatar
I have a similar issue with mine. I regreased my shifter last week and now the hazard button doesn't light up. The hazard function works and I know the bulb isn't burnt out...
Old Jan 22, 2013 | 06:20 PM
S2K9grand's Avatar
So pretty simple solution the dam fuse blew out must have grounded when I disconnected it to grease the shifter... Thanks guys for the info... Peace
Booztin
Aug 6, 2010 06:59 AM
Booztin
Aug 4, 2010 07:32 AM
darkstar909
May 23, 2009 10:45 AM
DeeGYM
May 6, 2006 06:48 AM
JohnnyCat
Nov 15, 2002 06:26 AM
