HELP! Wheel lock
Old Apr 3, 2013 | 05:02 PM
Kengthao91's Avatar
Default HELP! Wheel lock
Ok just right now when I got home I parked the car, turn off the car, and then try to turn it back on to move it, but the wheel got lock and can't turn it to the on position.... Is there anything wrong? I've try wiggling the steering wheel while turning the key but it won't turn to the on position, the key goes up and down when turning but will not turn all the way to the on position.... What's is wrong and is there a button i have to push to turn it on? I can't find any button anywhere near the ignition.... HELP!!!!!! AND THANK YOH FOR YOUR COMMENTS
Old Apr 4, 2013 | 12:11 PM
ForNgoods's Avatar
There's a big red button on the radio control panel that say "engine start" under the driver side AC vent.
Old Apr 4, 2013 | 04:10 PM
Kengthao91's Avatar
Oh haha and I'm pretty sure there's something in the topic saying the key cant turn due to the steering wheel being lock (for dumb people who can't read).... You prob driving an automatic cuzz apparently you can't push the button if the car is not even on lol
Old Apr 4, 2013 | 05:10 PM
RTZX9R's Avatar
What section of the USA teaches such poor English? Wow.
Old Apr 4, 2013 | 06:32 PM
gregor_konstantin's Avatar
turn key to ON position and you should be able to move the steering wheel again. May need to start car if that doesn't work
Old Apr 4, 2013 | 06:58 PM
Kengthao91's Avatar
Can't cuzz the steering wheel is stuck... No matter how much you wiggle the steering wheel while tryin to turn the key, it just won't turn
Old Apr 4, 2013 | 07:01 PM
lltysonll's Avatar
http://www.asap-locksmith-buffalo-ny...ing-wheel.html
Your key could be worn out also. As well as the ignition lock cylinder.
https://www.s2ki.com/s2000/topic/101...lp-wheel-lock/ Try what xviper mentioned also.
Good Luck
Old Apr 4, 2013 | 07:07 PM
Kengthao91's Avatar
Thank you so much for the site.... I will give it a try
Good Luck
Old Apr 4, 2013 | 08:13 PM
xviper's Avatar
Have you even tried another key????? Instead of starting TWO threads on the same thing?
Kengthao91
Apr 4, 2013 08:15 PM
CB
Jun 24, 2009 11:21 AM
hellspare
Jul 30, 2008 10:31 AM
Catahoula01
Jul 29, 2007 01:28 AM
xxcptomxx
Feb 27, 2007 05:27 AM
