HELP! Wheel lock
Old Apr 3, 2013 | 05:02 PM
Kengthao91's Avatar
Default HELP! Wheel lock
Ok just right now when I got home I parked the car, turn off the car, and then try to turn it back on to move it, but the wheel got lock and can't turn it to the on position.... Is there anything wrong? I've try wiggling the steering wheel while turning the key but it won't turn to the on position, the key goes up and down when turning but will not turn all the way to the on position.... What's is wrong and is there a button i have to push to turn it on? I can't find any button anywhere near the ignition.... HELP!!!!!! AND THANK YOH FOR YOUR COMMENTS
Old Apr 3, 2013 | 05:21 PM
lltysonll's Avatar
Hold the steering wheel using constant/even pressure in direction where it feels springy. Then turn the key while you apply the constant pressure on the wheel. Do not shake or rock the streering wheel. Do so gently.
Your key could be worn out also. As well as the ignition lock cylinder.
Good Luck and if any one else want to chime in please do so.
Old Apr 3, 2013 | 05:51 PM
Kengthao91's Avatar
I tried that, still won't turn, the steering wheel won't let me turn much, but thanks for te suggestion
Old Apr 4, 2013 | 06:15 AM
xviper's Avatar
Try your other key. There is no button like on some cars of the past. Key must be pushed in all the way.
Old Apr 4, 2013 | 08:15 PM
xviper's Avatar
You've got 2 threads going on the same topic. Close this one. In fact, close them both if you're not going to respond to peoples' suggestions.
Kengthao91
Apr 4, 2013 08:13 PM
DangerZone9K
Dec 27, 2007 07:49 AM
Catahoula01
Jul 29, 2007 01:28 AM
MugenRioS2k
Aug 8, 2006 03:01 PM
jcasta02
Nov 12, 2001 10:45 PM
