Hesistation in first and second
Old Mar 24, 2005 | 07:58 PM
carrnut21's Avatar
Default Hesistation in first and second
I just drove my dads 02 S2K, and right around 8,000 RPMs in first and second, it will hesitate for just an instant, then snaps back to full power, and pulls to the redline without any problem, it doesn't do it in third gear, and it doesn't do it every time in first and second. It almost feels like the limiter kicking in, but not as harsh. It was happening after i had been driving for about 20 minutes. The car only has about 10,700 miles, and we have only owned it for about a month.
Anyone have any ideas?
Old Mar 24, 2005 | 08:02 PM
Wisconsin S2k's Avatar
check the oil level. i bet you are low on oil.
in fact, i hope it's not dangerously low. that can cause damage, particularly on an engine that runs this hot.
Old Mar 24, 2005 | 08:39 PM
jwkim's Avatar
Former Sponsor
or it also can be your MAP sensor.
Old Mar 24, 2005 | 08:58 PM
xviper's Avatar
It may be a candidate for the MAP TSB.
Old Mar 24, 2005 | 09:38 PM
Colin's Avatar
Yup, MAP or TPS. Choose your alphabet.
Old Mar 25, 2005 | 07:43 AM
carrnut21's Avatar
Can someone explain the MAP or TPS thing a little better, i am still confused.
Old Mar 25, 2005 | 08:15 AM
xviper's Avatar
MAP = Manifold Absolute Pressure. This sensor is located on the top of the throttle body. Look at these threads about how to deal with it:
https://www.s2ki.com/forums/index.php?showt...ensor++problems
http://forums.s2ki.com/forums/index.php?showtopic=209708
https://www.s2ki.com/forums/index.php?showtopic=253242
TPS = Throttle Position Sensor. On some rare circumstances, this sensor needs to be "reset". There is a series of steps that must be taken to do this as it "forgets" what position the throttle plate is in. This prevents the ECU from running the engine properly. The Helm service manual outlines how to do this.
Old Mar 25, 2005 | 09:55 AM
ttah's Avatar
I had the same problem. I put a zip tie around my map sensor just to see... hesitation hasn't come back since.
tritium_pie
Feb 13, 2016 09:53 AM
Hondatuner82
Apr 22, 2014 05:56 AM
1stuey1
Mar 30, 2009 11:19 AM
